5.8.4.0 Tall Tabs
Conway
Hi!
Just installed 5.8.4.0 and found the tabs are so tall that I had to reduce the size of the 'log box' to read the box above it.
Also you can no longer tell what tabs are on the cart wall without mousing over each one... Thinking about reversing this update and waiting till the next one if I cant shrink these tabs
Can you please post a screenshot of how it looks like? What resolution does your monitor runs on and is there any scaling enabled in Windows?
forgot screenshot..
It appears the tab size is the only problem, the rest is displayed as it should. Please open Settings window, navigate to View->Style and reduce the "Tab size" value. The default is 27. After that it should be OK.
That was the cure, somehow when it upgraded it jumped the tab size to 60, reset it to 20 and now it looks great! Thanks for the continuing improvements! Love this software.
You're welcome! We'll further improve high DPI support in the next major update, and also take a look into why the tabs became tall.
