Bugs in 4.5.1.751
RBS
Hi Dj,
Found a small bug in 4.5.1.751-------"Settings-File Types"
I have enclosed a screenshot.
As you can see "File types from number 11 onwards are not showing the background colour.
File types 1-10 ( Previous version---No Problem)
Also the crossfades tab will show the correct colour/Background.
Regards
RBS
Hi Dmrity,
Ok A few other Bugs in the System, ( Small one's but Annoying! :()
In this new version of the Track Tool.....I think the waveform display is not as good as the old version.
Have a look @ the screenshot.
The amplitude focus is too much, ( I have normalised this wave to -1dB) but it appears that the zoom is too much.
Perhaps you need a +/- view on the Y axis (amplitude) like you have on the x axis( Time).
Point 2.
If I fill in the tag info --say album , year, genre, and then press the BPM detect button, and hit save ..I get "an error occured while saving tag information??????....Please press stop".( I am not playing the track when I edit)
Can this be fixed as I loose the tag info and have to redo it again.
Regards
RBS
1) It'll do auto-scale for Y axis in the next update.
2) Sometimes this happens if file has read-only attribute. I added it to the bug list, will be fixed.
Thanks.
