is it possible to get more precise information, such as the day, instead of "11:02:55 PM" for example? Otherwise you don't know on which day the song is played. For example "04-05-2020 23:02:55" (getplaylist2)
The "start time" returned by this command returns the contents of the "Start time" column in the playlist. It does not have date information. For that, you can use the getlastplayed command (the "LASTPLAYED" field).
When you use the getlastplayed command, the LASTPLAYED attribute contains both date and time when a track was played. For the current track you can get its information using playbackinfo and calculate when it ends based on playback position, sudration and current time.
Hey, we have the same problems, we also got our data from the getplaylist2 command, because we also want to know which next song comes after the next song, so we plan further ahead than just one song, a more precise date would be good for that.
