(N.) save tag, read TAG - problem
NICKY G DJ
I have a series of horoscope files that I download automatically, I have created a playlist of airing where I insert the sequence aries, bull, twins ....
The downloaded files have the same AUTHOR and TITLE tag (does not identify the astral sign file).
In RB, save the data in an SQL file.
In the Horoscope playlist, I manually type the TAGs, sign by sign, except for the tags and the playlist.
Now loading the playlist manually, it shows me the tag data that I put ... the problem arises when the next day I download the files again. the tags you insert and save in the playlist are overwritten again ...
1. But with the SQL DB I should not bypass this problem?
2. Is it possible to display the file name for certain files without an extension instead of the file tag?
RadioBOSS always reads tag when it's available. It only reads file name if a tag is not available. You can disable tag reading in advanced settings, but that will disable reading tags for all files.
