patrick.de-bruyn
Version 5.2 no Problem with Ads ShedulerIt is not possible to open ADS SCHELUDER in the new version.
The title is updated almost immediately here. What streaming server do you use?In the section (Broadcast) "Metadata" there is an option "Update title", can you please check how it works ... it seems that the option "On track start" does not work as it should. Refreshing the song title is quite late, it takes 1-2 minute, sometimes even more, to display the current song title correctly. It doesn’t have to be up to the software, it might be up to the server but just in case... pls check. Thank You.
zenoFMThe title is updated almost immediately here. What streaming server do you use?
You can contact their support in this case about the issue. We've checked and streaming title is properly sent to the server, unless RadioBOSS is configured not to send the title.zenoFM
Please press the Send bug report button, we'll see what could be wrong there.It is not possible to open ADS SCHELUDER in the new version.
More information is needed to reproduce it: how many tracks in the playlist, what is the number of the first visible track at the top, what track is being dragged.Dragging a track up to the top of the playlist scrambled and dragged other tracks. It happens up to the 50/60 track and then it's normal.
Se necesita más información para reproducirlo: cuántas pistas hay en la lista de reproducción, cuál es el número de la primera pista visible en la parte superior, qué pista se está arrastrando.
RadioBoss Errors 6.0.5.3. Drag tracks up to position 50. Flashing Events and Cover Sheet.Trying this here, but the files order is not corrupted when the file is being dragged from the bottom of the playlist to the top. If possible, please make a video illustrating the error.
Thank you, we'll check what could be wrong there.RadioBoss Errors 6.0.5.3. Drag tracks up to position 50. Flashing Events and Cover Sheet.
This file could be corrupted. If possible, please send it to us for testing support@djsoft.netRadioBoss Errors 6.0.5.3. Track Tool throws an error when wanting to modify .OGG files
Starting with version 6, it requires at least Windows Vista/2008R2 to run. It appears that Wine does not support some of the requires WinApi calls.We recently upgraded RadioBOSS to the latest version, but unfortunately it won't start under Wine because it crashes on startup.
Older versions 5.x.x.x worked fine under Debian 9 and Debian 10.
i also use zeno fm, yes, the artist and title often takes a little while to start updating and aftre that there seems to be a minute or so delay. the song plays and then the metadata reflect that about a minute later. I tend to supress the metadata for jingles, time announcement, news and weather as that is rather pointless, this seems to helpzenoFM
