RadioBOSS 6.0.5.0 Bugs
In the section (Broadcast) "Metadata" there is an option "Update title", can you please check how it works ... it seems that the option "On track start" does not work as it should. Refreshing the song title is quite late, it takes 1-2 minute, sometimes even more, to display the current song title correctly. It doesn’t have to be up to the software, it might be up to the server but just in case... pls check. Thank You.
The title is updated almost immediately here. What streaming server do you use?
It is not possible to open ADS SCHELUDER in the new version.
Dragging a track up to the top of the playlist scrambled and dragged other tracks. It happens up to the 50/60 track and then it's normal.
More information is needed to reproduce it: how many tracks in the playlist, what is the number of the first visible track at the top, what track is being dragged.
We have 200 Playback tracks and it happens in the first 50 tracks, when you drag upwards, a track that is lower is dragged, disorganizing everything in its path. After position 50 it seems not to happen.
Trying this here, but the files order is not corrupted when the file is being dragged from the bottom of the playlist to the top. If possible, please make a video illustrating the error.
RadioBoss Errors 6.0.5.3. Drag tracks up to position 50. Flashing Events and Cover Sheet.
  • WhatsApp Video 2021-04-23 at 08.29.03.zip
We recently upgraded RadioBOSS to the latest version, but unfortunately it won't start under Wine because it crashes on startup.
Older versions 5.x.x.x worked fine under Debian 9 and Debian 10.
Thank you, we'll check what could be wrong there.
Regarding the flashing cover art, please do the following: open Settings, General, Advanced configuration. Set "Playback debug log" to "True" and restart RadioBOSS. Wait for the flashing problem to appear. Then click Settings, Open Settings Folder. Open Logs folder and send us the "playbackdebuglog.txt" file to support@djsoft.net
RadioBoss Errors 6.0.5.3. Track Tool throws an error when wanting to modify .OGG files
This file could be corrupted. If possible, please send it to us for testing support@djsoft.net
Starting with version 6, it requires at least Windows Vista/2008R2 to run. It appears that Wine does not support some of the requires WinApi calls.
i also use zeno fm, yes, the artist and title often takes a little while to start updating and aftre that there seems to be a minute or so delay. the song plays and then the metadata reflect that about a minute later. I tend to supress the metadata for jingles, time announcement, news and weather as that is rather pointless, this seems to help
