M morrinsvilleradio New member Aug 4, 2022 #1 I was hoping to use a subfolder to store random Jingles specific to that show but doesn't seem to want to play ball. any ideas?
D djsoft Well-known member Staff member Aug 5, 2022 #2 You can add random track for a folder using the scheduler (use the wizard, there's an option to do that). Alternatively, you can build playlists using the Playlist Generator: https://manual.djsoft.net/radioboss/en/using_playlist_generator_pro.htm
M morrinsvilleradio New member Aug 6, 2022 #3 djsoft said: You can add random track for a folder using the scheduler (use the wizard, there's an option to do that). Alternatively, you can build playlists using the Playlist Generator: https://manual.djsoft.net/radioboss/en/using_playlist_generator_pro.htm Click to expand... I dont seem to have that Im using RadioBOSS Cloud v1.5.4.3
D djsoft Well-known member Staff member Aug 8, 2022 #4 morrinsvilleradio said: I dont seem to have that Im using RadioBOSS Cloud v1.5.4.3 Click to expand... I thought it was a question about RadioBOSS. In RadioBOSS Cloud, you can use the Track List feature, but it's not exactly for that.
