gustavo-rene.franco
Hi Dimitri!
query, where can you download 6.0.5.4 to be able to test it? ...From already thank you very much
I did as you suggested but I still have tracksold.db in that directory. I reinstalled the latest version againYou can try the following: click Settings, Open Settings Folder. Close RadioBOSS. Go one folder up, and find the "Tracks.db" file and rename it. Start RadioBOSS - this will make it create a new database.
No, the latest is 6.0.5.4, I upgraded successfully todayThe latest version at this moment is 6.0.5.3: https://www.djsoft.net/community/threads/radioboss-update-announcements.4325/post-35288
Am having the same problem, my "On Air" light is on only to discover there's no data out, may be I need to downgrade which I didn't want if there's a solution that can keep me in the current version!6.0.5.2 also had the audio playback freezing problem referred to above but I think I was able to fix this by increasing the audio buffer setting on the playback soundcard.
There's a possible issue that can lead to minor freezes in the couple of previous versions (starting with 6.0.5.x), we'll release a minor update later today to fix it.Am having the same problem, my "On Air" light is on only to discover there's no data out, may be I need to downgrade which I didn't want if there's a solution that can keep me in the current version!
I did but as for me the "On-Air" tab lights up but online listeners hear "silence", what else can I do?Please try the latest 6.0.5.5 update: https://www.djsoft.net/community/threads/radioboss-update-announcements.4325/post-35513
In my case, the audio mix will not send to online listeners everything but what is playing in RB even if the volume is lowered but even if a presenter is speaking, online listeners only hear that music, To me previous version does my job well!Please ensure that "Source" is set to "Audio mix" in the settings: https://manual.djsoft.net/radioboss/en/broadcast.htm
6.0.5.5 seems to have solved the NAS dropout issue although I have yet to do a more thorough test. The database log however has the following error message: “Out of range value for column “level” at row 1 (1264).” The tracks2 table in MariaDB has no length value set for the level parameter. Is this a bug or can you tell me what entry I should put in? I’m not an expert in MySQL databases....thank you for your work!Please try the latest 6.0.5.5 update: https://www.djsoft.net/community/threads/radioboss-update-announcements.4325/post-35513
Unfortunately, my mixer is connected to 7 mics that is why the older version does well with all mixer output connected to computer mic input as "Input 1"in RB. ItWhen you select Audio Mix it will stream what is playing in RadioBOSS and if you use MIC button it will also be included in the stream. The volume control under the playlist does not affect streaming - the stream always goes with full volume.
I did downgrade to and all works wellDo you use the integrated server or you stream to the other server? Is it 32 or 64 bit RadioBOSS version?
You can install the previous version using this link in case the problem persists: http://dl2.djsoft.net/radioboss_setup_6.0.4.0.exe
Yes I am using Heidi to examine what might be causing the problem with the database.Do you edit the database manually entering the values using some MySQL editing tool?
If you use the mixer, then you need to connect it to one of the inputs and then use it as a source for streaming: https://www.djsoft.net/community/threads/using-mixer-board-with-radioboss-for-streaming.6384/Unfortunately, my mixer is connected to 7 mics that is why the older version does well with all mixer output connected to computer mic input as "Input 1"in RB.
