RB 6.0.5.4 Broadcasting problem
Yes I am using Heidi to examine what might be causing the problem with the database.
If you made any edits and after that it started to show errors, I'm afraid I can't help about it. If you have a backup, you can restore it. Or just delete/edit the record that causes problems.
Actually no Dmitry, we have not made any edits or changes. We used HeidiSQL only this month as a diagnostic tool once we discovered the errors in the database log, which appear to have been there since last year. The database backup/restore in settings is greyed out. I would prefer not to have to re-create the database at this stage as it will disrupt our operations, but maybe its the only solution....
While there are errors in the log, do they affect operation? If not, you can ignore those errors.
In your error log it says “Out of range value for column “level” at row 1 (1264).” - I guess you can search for this value in the database and edit/delete the offending row. Maybe this will get the database fixed.
