• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RadioBOSS Cloud [beta]  (Read 100965 times)
0 Members and 2 Guests are viewing this topic.
SertanejaPop
    • Sertaneja Pop
Re: RadioBOSS Cloud [beta]
« Reply #135 on: February 14, 2019, 09:17:24 AM »
I'm not sure I understood the request.
Artist X feat. Artist Y and in sequence he repeats Artist Y. In RadioBoss software this happens.
SertanejaPop
    • Sertaneja Pop
« Reply #136 on: February 14, 2019, 09:18:50 AM »
What reporting period did you select?
I used the last month button.
  • Administrator
    • http://www.djsoft.net
« Reply #137 on: February 16, 2019, 10:09:13 AM »
Trying to move files in filezilla to a different sub directory results in an error '550 unable to rename file' . I believe this is a permissions issue, is there anything you can do to resolve this?
Renaming and moving the files is not supported by the current FTP implementation. You can only upload, download and delete the files.
  • Administrator
« Reply #138 on: February 16, 2019, 10:11:58 AM »
We have this feature planned for the future versions. It's currently under development, but it can take a while.
Thank you. We'll check if something is wrong there.
Radio Radio
« Reply #139 on: February 16, 2019, 12:08:07 PM »
I have 4 accounts with RadioBoss Cloud 3 on c2 server and 1 on c3 server. Non of the accounts generate a report. The only thing what appears is a header with blank fields.
Am I doing something wrong or is there a fix in the make...
For the rest we are super happy and satisfied with RadioBoss Cloud!!
  • Administrator
« Reply #140 on: February 16, 2019, 02:55:52 PM »
The fix was released just now, please try again, it should work now.
  • Administrator
« Reply #141 on: February 16, 2019, 02:55:59 PM »
RadioBOSS Cloud 0.5.9 beta
What's new
  • Email notifications in case of errors or silence (disabled by default, can be turned on in settings)
  • Minor user interface improvements
  • Fixed downloadable reports were empty for some accounts
Radio Radio
« Reply #142 on: February 16, 2019, 04:28:08 PM »
It gives me now an error:
"an error occurred: An Error Occurred: 0"
The player in top bar goes to E0
Thnx
Radio Radio
« Reply #143 on: February 16, 2019, 04:32:17 PM »
Also,
Would it be in the future possible to generate a report, automatically set with the Mount Point or Station Name instead of standard "report"? (Fairly unimportant but it would convenient)
and,
Set how long the silence would occur before a silence is detected (we are very happy with this solution!)
Thnx again for all the greatness!
Radio Radio
« Reply #144 on: February 16, 2019, 04:39:27 PM »
Thnx
It still doesnt work if I want to export a month by month list. Probably a "timeout" with the server. I can however export a list for 2 days. Is there a way to change the execute time of the server?
tking
« Reply #145 on: February 18, 2019, 09:28:34 AM »
Hmm ok that's quite a limitation. Is it something that will be implemented anytime soon?
  • Administrator
« Reply #146 on: February 18, 2019, 09:43:50 AM »
An update was being installed on that day and it may have caused those errors. Even while you had seen those errors, the stream should be working (for most accounts, the average downtime was about one minute).
Do you mean adding a custom header for the report?
Currently it's fixed at 30 seconds. We'll consider adding a configuration option for this in the future.
  • Administrator
« Reply #147 on: February 18, 2019, 11:45:39 AM »
We'll take a look into it, the fix should be released within 1-2 days.
Yes, I think this would be possible fairly soon.
Radio Radio
« Reply #148 on: February 19, 2019, 02:06:48 AM »
I love the possibility to generate reports for FCC here in the US and Copyright companies, but also as a proof when, and on what time a certain song/commercial has been played! Thank you!!
Issue: When I stopped the radio-player (playlist) with 4 minutes of silence, it didn't generated any email error report for us. We have not received an email or spam. The box was marked with "Send email notifications in case of any errors or silence"! If it doesn't generate a report by manual silence, it would be great to send a "test report" or have a "test functionality"! This function in combination with sending auto text messages when certain email are received in my email box will give me a lot of extra sleep. In this case I can receive a text alert when emails are send by error or silence. (See below links for instructions)
https://www.cnet.com/how-to/auto-forward-important-email-to-your-phone-as-a-text-message/
https://www.howtogeek.com/210956/how-to-configure-automatic-text-message-alerts-for-important-emails/
Couple of small things I believe would be great improvements:
1) The reports can not be generated if you use a large amount of data. For example: If we generate a monthly report, the server gives a time out error. (probably because it takes to long to load)
2) It would be great if the generated report is automatically saved with the station name and dates the report is generated for. If I want to generate 4 reports from 4 different days, all reports will be saved as "report". It would be great if it would be for example: "[Station Name] + [Date Reports Generated]" WKOM Radio report 2019-2-2_2019-2-8
3) Would it be possible to publish somewhere the headers of the reports used in CSV or export the reports with headers?
4) It would be Super if you can ad a custom field with info in -> Media -> File Manager -> Tracks ->Tag Editor which will be exported in the report as-well. Specially for notes in regards the tracks or spots being played.
5) Would it be possible in the future to make a selection WHAT the reports are exporting. It's a small thing to delete the info not needed, but it would save time and CPU if you could pre-select the info WHAT you like to export in a report.
6) Export functionality in ZIP?
For the rest: We LOVE the way RadioBoss Cloud works!! Impatiently we wait for future developments. We are running 4 RB Clouds for 3 FM stations and 1 AM Station in Metropolitan areas without any Flaws!!
Many THNX!!!
Marty
Radio Radio
« Reply #149 on: February 19, 2019, 10:06:03 AM »
Update:
I received the error email, 3 hrs and 3 minutes later. What would have been way to late.
