• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RadioBOSS Cloud [beta]  (Read 108275 times)
johngrant
Re: RadioBOSS Cloud [beta]
« Reply #390 on: February 26, 2020, 07:22:06 PM »
Coming in late here.  Is this available?  Is there a spec doc?  I have an older RadioBOSS Standard license playing only RSS feeds/filename commands to a RadioBOSS.fm shoutcast account.  Can I port/copy schedule events, overlay playback, HTTP get statements. Want to replace an old, noisy laptop server with a cloud deployed solution.  Thanks.
  • Administrator
    • http://www.djsoft.net
« Reply #391 on: February 28, 2020, 07:15:27 AM »
You can read about RadioBOSS Cloud here: https://www.radioboss.fm/radioboss-cloud/
30 day trial is available to test how it works.
  • Administrator
« Reply #392 on: February 28, 2020, 03:42:54 PM »
RadioBOSS Cloud 0.8.2 beta
  • Added listener statistics by country and TLH
  • Improved Reports section user interface
  • Minor UI improvements
johngrant
« Reply #393 on: February 28, 2020, 06:25:19 PM »
It rocks.  I switched off my classic RadioBOSS last night and moved the whole schedule up there.  Love the Tweet and Tunein API support.  Looking for a replacement for the HTTP GET support, especially use of track information variables. Will scheduler support URLs with those variables? I had some scripts written on my web site that handled those variables passed in URLs. Would like to use those still if possible. Thanks.
  • Administrator
« Reply #394 on: February 29, 2020, 06:28:38 AM »
Do you want to use the custom HTTP requests from RadioBOSS Cloud?
RadioBOSS and RadioBOSS Cloud share the same scheduler core, so most features that present in RadioBOSS will also work in Cloud.
johngrant
« Reply #395 on: February 29, 2020, 09:34:01 AM »
Yes. It was under Settings > Reports > HTTP GET request. Those were very useful. Thanks.
Radio Radio
« Reply #396 on: February 29, 2020, 11:26:32 AM »
Q in regards of users settings:
I have set several users for streaming, for our Live Ballgames, however, they have with JUST the setting "STREAMING" as user access to my billing and ticketing section. Also to Overview (Where they can use the files in folders to change whats playing) and "Information"...
Is it possible to restrict the USER setting litterly to what is says? I do not want my employees to go to overview and for sure to billing and/or overview settings
SertanejaPop
    • Sertaneja Pop
« Reply #397 on: February 29, 2020, 04:33:25 PM »
I didn't quite understand, is most of my ears in the United States? Since in fact my audience is in Brazil
John Drake
« Reply #398 on: March 01, 2020, 10:00:09 PM »
Quote (selected)
It seems that you have used the http link for Tune In, change the link to the https one - you can find the link in the Information section.
Should the TuneIn listing contain just an 'https' stream (one URL), or should it include an 'http' as well as an 'https' stream (two URL's)?
  • Administrator
« Reply #399 on: March 02, 2020, 06:51:36 AM »
Those areas are not accessible with only Streaming rights - it will not allow changing playlist and preform any actions. We can add a new rule - "Login" to prevent logging to the control panel completely, what do you think about it?
It uses MaxMind database to translate listener's IP addresses to country. It's either you have lots of US listeners, or that your listeners use VPN with IP address in the US or the database is simply wrong.
I don't know - please contact TuneIn and ask what link they need. But according to the recent events, HTTPS links should be used everywhere now, and HTTP is the thing of the past.
  • Administrator
« Reply #400 on: March 02, 2020, 08:14:31 AM »
An update on this issue. There's appears to be a bug in both numbers and countries - we'll address this issue ASAP.
SertanejaPop
    • Sertaneja Pop
« Reply #401 on: March 02, 2020, 11:58:49 AM »
I find it almost impossible for 90% of my audience to use VPN.
My station was off on chrome browsers, I contacted Tunein to update "https" and the problem was solved.
Radio Radio
« Reply #402 on: March 02, 2020, 12:02:45 PM »
Quote from: Radio Radio on February 29, 2020, 11:26:32 AM
Yes, that sounds great! Thank you!!
REPORTS:
Also, another smaller issue: When downloading reports, (which we have to do month by month because it only allows max of 60 days, but thats ok) it would be great if you can select date range "from - To" in the same month. (because of the 60 days issue.
For example "July 1 - July 31" - So it takes all data (Report Type -> LIST) from:
July 1, 12.00.01 am - July 31, 11.59.59 pm
In that case it will be really a calendar month. Now the only possibility is July 1 - August 1, which ALSO includes the first day in August. (Its not possible to do from July 1 - July 31)
CLOCK:
It would be great if there was a tap in the admin with just a giant clock with time + seconds till end of song (or file) and how many seconds next song or file is etc. Something what a DJ or Host can look at to take over live shows from automation etc. We use a large screen on roughly 14 feet away (3 meters) and never can see the next file/song/time/how many seconds minutes left etc. - I know this is a luxury, but it would DEF. a big help in making accurate tight radio.
SERVER LOCATION:
Question: Our radio stations are based in central US. My server is in Europe (paris?) We have a 10-12 second slack time. Would a server based in the US work faster with less slack? Would it be possible to move everything over? Please advice!
Thnx Again for all the greatness
Radio Radio
« Reply #403 on: March 02, 2020, 01:08:50 PM »
REPORTS: REPORTS:
I MADE MISTAKE!! I see you can select IN the month. My fault thnx
SertanejaPop
    • Sertaneja Pop
« Reply #404 on: March 03, 2020, 02:19:10 PM »
Is that a bug? Anyone else with this problem?
Transmission dropping frequently and this message appears at the top of the panel, see the print. This happens in others as players well.
