Chris Deacon
I'm confused about the correct use of the streamarchive config menu.  If I have two different recordings to make and each gets saved in a separate directory location, do I use the config menu plus the streamarchive on scheduler command, or do I specify the paths in the scheduler command (streamarchive z:\AUDIO\myshow.mp3)?
Can I use flac for one scheduled command and mp3 for another, or should they always be the same (as specified in the streamarchive config menu)?
I also find the red button confusing and illogical. Most recording devices light the button red when recording and black when off. Can this be changed in a future version? Even a slow flashing red button would better indicate recording has begun!
